Parting out r32 gtr half cut let me know what you need . Also have rear end minus shafts and hubs
R32 gtr front seats $600 no rips
Tein coilovers $550
Rear non vspec diff looks very fresh stock 2 way $450
Nismo front strut brace $100
Extra gear box $500
R34 gtr parts
Parting out motor number one cylinder only had 100 psi diagnosed ring. Let me know what you need
Hks 2530 X2 has the usual bit of play still in good working order $2000
Mines ecu $500
Mines front pipe damage ask for pics $100
Mines 3 inch cat $150
Mines dump pipes $350 pair bell mouth
Excedy tripple plate carbon clutch plenty of meat left $1500
6 speed getrag 70 thou kms with transfer case and shifter $5000
Brembo 6 pot 4 pot brakes with rotors brake lines and adaptors $3500
Near new recaro sr6 $900
Nismo cluster $400
Located belmont nsw
Pick up or can post australia wide
All pms replied
0402555849 or pm for pictures
Ill check on the other parts you guys have requested tomorrow morning
Should have a air box and definetly still have the power steering pump with bracket
Will you sell the exhaust side cam cover from the r34 motor? If so how much?
Brembos sold
Nismo brace sold
R32 gtr dr seat sold
Recaro sr6 is one seat . I'll up load some more pics
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
