Hi Guys,
I have a brand new complete custom Fortune Auto 510 series coilover setup with air cups to suit r33/r34 gtr. I bought these about 1.5 years ago and had to be custom made to suit the car.
They have air cups front and back which when enabled give the car 2" of lift and when they are done they are completely solid which means they dont affect performance of the coilover itself. THey are 510 series coilovers with the optional swift spring upgrade. Similar sort of setup to what you see in high end sports/super cars as it allows you to get in and out of driveways (or raise it up for an rbt bay) without affecting performance in any way.
It comes complete with everything for installation including the struts and cups, compressor, tank, fittings, lines and switches. It's all brand new in boxes as I have never gotten around to fitting it. Photos are of one front strut and a photo off the website of a complete setup except I have air cups front and rear.
I paid $5k for it back then and with the exchange rate the way it is right now it'd set you back over $6k for the same setup. I am chasing $4500 ONO. Spring rates are 10 front 8 rear.
Pickup is preferable but will post at buyers expense. Items located in Rouse Hill, NSW and best contact is 0403858714.
Thanks,
Brett
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
