Dolphin front bar $912 plus shipping, taxes and charges. Maximum flow
Just too bad if you want to actually lower your car, that bar is huge!
Also a shame that dolphin uses fibreglass, fibreglass is ewww
One of the guys near me has a takero front bar and had to cut off the bottom of it and refibreglass it as it was so low. Aero is lyfe
Just go takeros lip on aero bar. Just adds little wing things to side to tie in with side skirts
My engine temps did not change from running the stock tiny intercooler to running an HDi kit.
Scotty's cooling mod, and a larger capacity radiator will improve the cooling system's ability to shed heat.
IMO; the OEM (quite noisy I agree) is far superior to thermo fans for heat management.
I've run a number of different setups using high capacity fans, and custom made shrouds to ensure efficiency, and nothing works better than the stock Clutch fan.
I did notice an improvement in cooling system performance when I changed from the stock "smiley face" front bar to the Aero Kit front bar.
i can't accurately compare the water temp between stock and HDi due to the outside temp and traffic condition may different.
for the cooling system, i have nismo thermostat, full alloy radiator, breath tank, Motul Mocool, just missing scotty's mod. i agree scotty's mod could stabilise water temp, but less effect when stuck in traffic on hot day? it is all good if my car is running above 30-40km/h all hot day, just problem when stop on idle, especially when aircon is on. if i go hardly even though at very low driving speed, then water temp will go down a bit. it seems the stock noisy fan or waterpump can't flow enough air/water when idle.
Scotty's cooling mod lowers temps across the board, and allows cooling system to rapidly drop temp after any kind of load related cooling temp increase.
If you did nothing else to the cooling system; this mod would be the one I'd do first.
  • Like 1
This will be one of my next mods. I need to do a cooling overhall with alloy radiatior and cooling mod etc
Talk to Scotty about the radiator; he now uses an OEM style replacement (alloy core/plastic tank) uprated core that is much easier to fit than the off the shelf all alloy units.
  • Like 1
The Nismo front bar is 11ty billion times better looking than that abortion.
Shame about the head in the car... ;)
10838001_10153122897702217_6404291385902
I think the Dolphin front bar is priced 300% what it should be and it's actually quite ugly if you look close at it.
Heaps of hard edges, brake ducts way too big, exposing too much, hence the sign in the pic.
Looks tough but lacks sex.
Nismo kit beats it hands down.
For me the Axis Autech looks the best.
I really dig the bling of the Axis chrome grille.
It just brings that elegance this car deserves..
Edited by conan7772
  • Like 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
