Hi all, not sure if im posting in the correct place, but i have an r33 gtr. i dont drive it very often but when i do the car feels very weird in the rear, unstable and seems to feel as though the rear is "walking out". the hicas seems to be working fine subframe bushes "appear" to be fine also tie rod ends etc are fine. iv'e tried a few wheel alignment settings, currently 1mm toe in rear 1mm toe out front. im runnning mines esca street coilovers and thats all as far as suspension items go. it doesnt feel normal at all, iv'e driven other cars with hicas before and owned an r33 gtst for 5 years previously, neither felt like this car. Anybody else had this problem? fixes? etc. cheers
https://www.sau.com.au/forums/topic/453827-r33-gt-r-handling/
1mm toe OUT front - geee, put it 1mm toe IN and you'll be sweet.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
