Hi,
Looking at getting a set of Work 11r for my R32 GTR, Gun metal grey in colour.
I am trying to decide on colour, and at the moment its between bronze or glim silver. I know its all personal choice, but I would like to know peoples thoughts..
size will most likely be 18x9.5+20
Cheers
https://www.sau.com.au/forums/topic/453919-work-11r-colour-choice/
