Sorry for late replys.
I think I still may have side skirts .
Have the harness minus coil pack loom.
Turbos are stock .
Down pipe I have 1 mild steel and 1 stainless
Wing sold
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
