<500cc Side Feed Injectors - Rb25 Neo
Oh really? I thought all 25's were side feed. I better have a look then :S Is there any real way to tell, will the injectors be litterly flat to the block if its a side feed?
Thanks fellaz.
I've gone from SR to RB and I know almost nothing about them yet :unsure:
Edited by Linnertson
https://www.sau.com.au/forums/topic/453996--/#findComment-7482755
It's very easy to tell. On side feed rails the injector heads protrude past the rail and are retained with caps. On the top-feed rail of the Neo the injectors are retained by the rail i.e. the rail is the highest point.
The SR uses a side feed rail and it looks similar to non-Neo RB25's.
Edited by colourclassic
  • Like 1
https://www.sau.com.au/forums/topic/453996--/#findComment-7482907
I checked just then and yep, looks like a top feed. I understand now because I know my old SR had the caps so that makes sence, thanks guys all this knowledge helps :)
I dont really plan to run E85 tbh, just because theres no one that close I would fill up on in the north shore (and I do weekly trips to newcastle).
https://www.sau.com.au/forums/topic/453996--/#findComment-7483403
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
