Just want some advice from people who have used these clutches first hand http://www.kudosmotorsports.com/catalog/exedy-exedy-heavy-duty-cushion-button-clutch-kit-nsk7056hdcb-nissan-skyline-hr31-jdm-r32-gts4-gtst-r33-gts25t-p-14.html and would like to know if they are a good clutch or is there something better i can get for around that amount that is daily-able and can handle all the clutch kicks. Thanks!
https://www.sau.com.au/forums/topic/454333-clutch-for-daily-drivendrift-days/
My NPC carbotic also felt just like stock when I was using 32 gts-t clutch master cylinder. Using 33 clutch master and it is slightly heavier but nothing ridiculous. Still very light for what it is able to handle.
NPC 10inch carbotic button clutch stock pedal feel cost around $700 and will handle 400kw best option by far.
Ouch. I paid $1200 iirc for the same clutch but pull type. Shows how much more expensive they are. This was 2 years ago though.
Shit thats a big diff, where did you buy from? I bought about 8months ago.
Direct from NPC. Shows the price difference between Push and Pull. And that was just the clutch/pressure plate assembly. No flywheel.
Yeah ive seen it with other clutches aswell pull version is always more but this is almost double haha crazy.
Got my carbotic with npc flywheel for $600, love the for sale section, bought the pressure plate new as well...
Pedal feel is good, but the grab is nowhere near stock, especially in reverse... It does love to be dumped though
  • 3 weeks later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
