Hi All,
I have read up about similar issues on the forum but still unable to locate my problem.
My stag has a miss at idle and in high rev range but not too bad though the middle I have changed coils and the car comes good for a day then back to missing again. Plugs are only 1000km old gaped to .8, new AFM. I have pulled the plugs out and the drivers side look really good but the passenger side look a bit black compared to the drivers side.
Please help, any ideas?
https://www.sau.com.au/forums/topic/454380-m35-stagea-missing/
ok checks hoses, all look and feel ok.
I started unplugging coild packs 1 by 1, passenger side no change when removing drivers side as soon as i unplug 1 the car runs ruff.
Its only running on the 3 drivers side cylinders??? WTF??
anyone heard of this?
Also, check for error codes. Could be Cam pos sensor on left bank if there are no related mods like ecu piggyback, coil packs, etc.
Which plugs did you put in?
I used NGK Iridiums LFR6AIX-11 but gapped down to .8
I have checked for codes but there is nothing there...
It feels like a timing issue to me...I have swapped out the rear sensor on the left bank.
Good chance you damaged the plugs, they are too fine and brittle to gap down if you have done so.
I use LFR7aix, but a stock M35 should be fine running the hotter 6's. The plugs I use though are already gapped at .8mm, and I run mine up to 40psi without a problem on the original 14 year old coils.
Any sensor issues will be quickly picked up by the ecu and a fault light will be displayed. What the ecu doesn't know is if you plugged the coilpacks in the wrong order for example. It's very easy to mix the front plugs up, try swapping them around.
Cheers Scotty I will give it a go
Ok swapped out the plugs to the old ones (LFR6aix-p) no change, the front 2 coil plugs can't get swapped on mine as there isn't enough length in the plug wire..... ?
On the passenger side? The rear two can be mixed up then yeh? It's the coils where the plugs sit back to back you need to worry about, I have seen them mixed up many times, sometimes it's even my fault. :P
  • Like 2
checked again Scotty, but I was able to get any mixed up with my Stagea as the length of each plug will only go to 1 spot. I did change 3 of the spark plugs back to the old one and it seemed to make a bit of difference to the mid and top end, i will change out the other 3 this weekend coming as I don't have the car with me. I'm also replacing the PCV valve too see if that make any difference to the idle.
I have been also thinking of do an injector clean, good idea??? I'm thinking it cant hurt to do it....
If anyone else has any ideas, they would be greatly appreciated.
I can send you a refurbished set of injectors if you like, but that probably won't be the issue. You can most definitely mix up two of the plugs on each side, the ones that face each other where the plugs are nearly touching. Try it out before anything else...
I swapped over the plugs but it only just reached....you can see in the pic the front and middle are different lengths, the drivers side could get mixed up.
I'm really starting to lean towards injectors
Scotty if can pm me about the injectors you have, that would be great, unless any other ideas
ok yep, i swapped them around, no good.
i pulled the injectors, all good nice and clean, flowing nice.
i was having a listen to the exhaust and i think there might be something loose there and when the turbo comes on i can hear a different noise i havent heard before, im also using more fuel then usual, im going to have a look into the exhaust this weekend coming. could be a blocked exhaust all along.....
i love solving problems but i hope i can solve this soon cause its really giving me the shits!!! lol
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
    • Here's Logans Silvia with R32 Drivetrain, mine will be slightly lower (more angle). He was constantly blowing the RH axles at around 16deg. I want to avoid this.
