G'day just in need of some advice, currently having my rb25det rebuilt,
Mods relevant to the issue are
Cp Pistons Sc7305 86.5mm 9.0:1
Bridgeway forged rods
Block was decked
Been told Comp ratio is only 8.4:1 and pistons are .029" out of the block deck.
Any help appreciated. Cheers guys.
https://www.sau.com.au/forums/topic/454457-rb25det-rebuild-issue-help/
Doesn't seem possible. Are you sure that they are normal RB25DET pistons, or is it possible that they are for a Neo?
If they are the correct pistons, what is the value of the volume of the "dome" portion of the piston? We can neglect the slight poke of the piston out of the block and use the normal 25 chamber volume and the dome volume to calculate what the CR theoretically is.
  • Like 1
Just doing a real quick and dirty calc, ignoring deck height issues and the gasket thickness, the 63cc chamber, 416.3 cc swept volume and 8cc domes gives 8.56:1 ratio. So close enough to the 8.4 reported before.
FWIW, doing the above with Neo 51.5cc chamber gives 10.5:1.
Ergo, it is hard to believe that these are 9:1 pistons under any circumstances.
Yes
It's wierd
Yep, just got 8.48:1 using a 1.0mm thick gasket
Good on you or your builder for actually checking.
I'm betting heaps get slapped together with no idea of the compression ratio.
Very true, I had CP pistons put in my RB25DET and I don't believe the CR was checked.
as unfortunate as it is for you. its good info for anyone wanting to buy CP slugs in the future.
Zebra could you calc using 17cc instead of the original 8cc stated?
The stroke measurements were incorrect in a book he was using or something along those lines? It has now come up with 10.5 compression ratio with taking into account the .029" out of the block.( which is probably from being decked too much)
Head cc is 62.8cc
Edited by Muskett
9.9ish:1 using a 1.0mm gasket and 0.8mm out the bore
edit, given that the piston is 0.74mm out of the bore, it works out at 9.84:1 with a 1.0mm gasket
1.3mm gasket is 9.53:1
He came up with 10.5:1 with the standard nissan gasket and the 0.74mm out of the block ( obviously can't use this combination but for calcs)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
