G'day just in need of some advice, currently having my rb25det rebuilt,
Mods relevant to the issue are
Cp Pistons Sc7305 86.5mm 9.0:1
Bridgeway forged rods
Block was decked
Been told Comp ratio is only 8.4:1 and pistons are .029" out of the block deck.
Any help appreciated. Cheers guys.
https://www.sau.com.au/forums/topic/454457-rb25det-rebuild-issue-help/
Doesn't seem possible. Are you sure that they are normal RB25DET pistons, or is it possible that they are for a Neo?
If they are the correct pistons, what is the value of the volume of the "dome" portion of the piston? We can neglect the slight poke of the piston out of the block and use the normal 25 chamber volume and the dome volume to calculate what the CR theoretically is.
  • Like 1
Just doing a real quick and dirty calc, ignoring deck height issues and the gasket thickness, the 63cc chamber, 416.3 cc swept volume and 8cc domes gives 8.56:1 ratio. So close enough to the 8.4 reported before.
FWIW, doing the above with Neo 51.5cc chamber gives 10.5:1.
Ergo, it is hard to believe that these are 9:1 pistons under any circumstances.
Yes
It's wierd
Yep, just got 8.48:1 using a 1.0mm thick gasket
Good on you or your builder for actually checking.
I'm betting heaps get slapped together with no idea of the compression ratio.
Very true, I had CP pistons put in my RB25DET and I don't believe the CR was checked.
as unfortunate as it is for you. its good info for anyone wanting to buy CP slugs in the future.
Zebra could you calc using 17cc instead of the original 8cc stated?
The stroke measurements were incorrect in a book he was using or something along those lines? It has now come up with 10.5 compression ratio with taking into account the .029" out of the block.( which is probably from being decked too much)
Head cc is 62.8cc
Edited by Muskett
9.9ish:1 using a 1.0mm gasket and 0.8mm out the bore
edit, given that the piston is 0.74mm out of the bore, it works out at 9.84:1 with a 1.0mm gasket
1.3mm gasket is 9.53:1
He came up with 10.5:1 with the standard nissan gasket and the 0.74mm out of the block ( obviously can't use this combination but for calcs)
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
