So noticed last week when going to get fuel the speedo wasn't moving. Checked the Power FC to get the reading. It also read 0. I noticed on the way home though that both Speedo and Power FC now were displaying correct speeds.
Took it to the mechanics for a few other maintenance items and yet again speedo stopped working. Assumed from here it was the speed sender behind the gearbox. Just had a replacement installed at mechanics and no dice. Mechanic traced the wire all the way to the loom and no splits in the wire.
So what options can there be to look at or anyone else experienced similar, and best profession to look into it ie. Auto elec?
Details if required
R33 GTR
Nismo Dash
Power FC D-Jetro
https://www.sau.com.au/forums/topic/454492-speed-reading-intermitently-working/
Dirty connection somewhere is my bet. Keep in mind that the speedo signal goes to the speedo before the ECU so if it is cut pre speedo, neither will work
I would check your connections from the gearbox loom and clean them if needed.
I have an R33 wiring schematic but it might not be relevant to the r34
It's R33 mate.. Interesting. I was under the assumption it went to ECU first. Would be interested in the schematic. Auto elec might be the first port of call then. Try track down where the fault starts
Sorry, was on mobile and could only see your name there, so figured R34.
I can have a look at the wiring diagram tomorrow morning and give you some info if you want. Because its not happening all the time, and when it does work the speed reads right (correct?) I'm assuming its a dirty/loose connection somewhere along the line or perhaps the early stages of a rub through/short.
If you have a multimeter, I'll give you some places to start. Probably re-do what the mechanic did but its best to know for yourself
Yeah Callan I assume speeds were correct. They seemed to be the speeds I thought I was going. It stopped working. Then on way home worked. Worked all the way to mechanics. Stopped working while at the mechanics. Replaced speed sensor. Still no go
Cheers Brad. Will have to just start crossing off the list I guess. Is there a way to ensure the replacement speed sensor is indeed working correctly?
The speed sensor would probably be ok when replaced. Next step would be to see if you get 0-5v at the ecu at pin 53. Then at least you know the signal is or isnt getting to the ecu.
O.K I have had issues in this area before with my reverse lights. They worked intermittently (funnily enough) and I bought a new reverse switch but discovered the problem before I put the new switch in. Reverse lights would flicker on and off etc
I've circled the speed sensor plug (top of drawing circled in black) and the plug I had problems with (was just dirty, cleaned it up, checked connections were good)
And in the next one it shows the same thing but in a wiring schematic, just so its easier to work out which wire is which. Its pretty easy looking at the plug to work out which wires are which. Just hold the plug and look at it in relation to which side of the plug on the drawing. If you need a hand I can help anyway. Ive marked around the plugs and put dots where the wires for the speed sensor are
Just found this as well, shows the speed sensor drawing as well
Edited by 89CAL
  • Like 1
OK, Bt of an update. Auto elec mechanic found a crack in the PCB and that has been fixed. All electrics checked apparently.. But still no speed. They can spin it manually and the speed goes up but no reading from car
Is it possible to get different speed sensors? He asked if I got an auto or manual sensor for replacement. Rang mechanic and said the only thing that was different was the gear on the end but he swapped them over so it has my original gear in it..
I'm going back to mechanic tomorrow to put original speed sensor back in just incase but any thoughts?
Bought a new cluster and I get the same problem. Wires have all been checked by auto electric mech.. but I cant say 100% as im just relying on what they say.
Now the speed sensor that was bought had a different cog on it. And seems it is also in a different position. So there is more than one speed sensor type for a 33gtr?
Wreckers only had that one speed sensor so what is the best way to aquire the correct speed sensor as i feel this is still my issue?
Alternatively. Is there a way to change the location of the shaft on the sensor? The replacement i got is offset the wrong way to fit a bigger cog. Is it possible to reposition it?
In some cars any ferrous metal debris floating around in the Trans can effect the induction pick-up and thus the speedo actually working
based on your latest discription it would seem there is no voltage supply to the induction sensor, remember these are essentially a Variable DC Square or Sine wave generator BUT will not work if there is no DC supply to the Sensor AND it the sensor is not adjusted correctly (this varies from 5-10 Thou to as much as 30 thou depending on the sensor and gearbox)
Have you checked that the fusible links are in good order? I have seen them mess with instrument gauges.
And by this I mean that they are making good solid contact and there is no corrosion, not just that they are not broken.
Edited by sonicz
This is true with non contact sensors, but I believe because the R33 use a driven speedo sensor it is not an issue
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
