hey i just got pulled over again and this time they must have heard my bov so they called a traffic cop to assist cos he was supposed to know whats, i played the "i dont know anything card" but when he said my boost controller was a bov as well as a boost controller i told him he didnt know sh1t so after he threatened to get his pen and paper out and start to write down everything wrong with it shut up, anyways i dont wana remove the bov cos i would have to weld up the hole in the fmic piping so i want turn it to a plumb back but i need the plumb back adaptor for a turbosmart type3 ss, if anyone has one please let me know or if anyone has any ideas how to make it plumb back another way that would be good, i got the stock parts but it would be a pain in the ass to do the bov
https://www.sau.com.au/forums/topic/454499-bov/
For sale section or buy from a turbosmart dealer. There are going to be no 'other' ways to make it plumb-back that are going to be easier then buying the right adapter and hooking it up. The adapter will cost stuff all (probably $30, if I could get a Greddy one for that price I'm sure turbosmart are close)
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492305
Rule number 1 when pulled over, act resectfully to the police, act dumb (dont know much about cars), and hope they spot something basic on the outside to write the ticket for so they dont open the hood, thats the sort of defect that can be easy to clear as in most cases being too low of having tyres sticking out of the guards simply means presenting the car to Vic Roads (or whoever is the equivalent in your state) for a inspection to clear just what got written up and nothing else.
My sons been done for having tyres out of the guards twice and (too) lowered once, all 3 times put stock parts on, lady comes out and looks, sees stock height or wheels, defect cleared, aftermarket parts bolted back on the moment it got home, Hwy patrol are constanly looking at it now, we are starting to think they have gven up as im sure the previous defects show up yet the car is back as it was and all they do is stare now.
Think of being pulled over as a bit of a attitude test.
You need to plumb it back, your not allowed to vent to atmosphere, its a simple as that now.
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492380
yeah thanks for the advice, that is very good advice. Yeah i will plumb back the bov if i can get the adapter plate or i will have to put the stick one back on and as for the dual stage boost controller im a lil bummed out about having to remove that, the dumb ass only knew to look at that cos its bright blue and looks obviously aftermarket, i seen that i can put the stock one on and ground the wire to keep it in high boost but thats only 7psi and i want the whole 12 that it can take safely, so i was thinking about going a 12psi actuator that can simply replace the stock one and then i can paint it black and put a nissan sticker on it just in case so it doesnt stand out. Does anyone have one for sale or know where i can get one cheap, and are they pretty much generic fit or do i need one specific for the stock r33 turbo?
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492746
Why not buy a discreet boost tee, some black boost line and hide the boost tee where you cant see it? If you think you only got caught because it stood out, then hide it somewhere better.
I think the R32 GTSt actuators run about 10psi. Honestly though, without an aftermarket ECU I wouldnt bother running any more then 7psi. I ran 10psi in mine through the stock ECU and it hit R&R badly and just wasn't real nice. Even when I got boost to the right point where it would run till redline, it was still not great. Did the high boost mod to the standard boost solenoid and running around 7psi again it seemed so much nicer.
My advice, take it or leave it. Save some money, buy an ECU with in-built boost control (Link/Vipec etc, even the PowerFC can do it with the optional boost kit) and get it tuned. You will be amazed how much better it runs, and if the tuner is good you will get better fuel economy and so on
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492879
yeah i am so i would have to remove aftermarket one on the fmic and have the hole welded up and then i can put the stock one back on the cross over pipe and plumb it to the intake, unless i can track down the plumb back adapter for the aftermarket one and then i can just simply plumb that one to the intake. Its a pain in the ass lol
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7493527
the original is a metal pipe that goes straight into the rubber air intake hose on the turbo and the other end just uses a bit of rubber hose to join the metal pipe to the stock bov, thankfully i still have all of the stock parts
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7494905
finding right size hose proving to be a little difficult but may be able to modify original pipe to shorten distance to front mount intercooler piping where new bov is located & 35mm hose is not real flexable lol
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7495329
if the hose from the plenium to the bov was blocked would the bov stay closed permanently, or would pressure in the ic pipe force it open sometimes?
i thought about fitting the stick bov back on in the stock location and leaving my aftermarket one where it is and then finding some kind of valve so i can run the plenium vac hose to both bov and have the valve set so i can direct the vac line to goto whichever bov i want at the flick of a switch, as long as the bov that isnt turned on doesnt open at all.
I hope i have described this right
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502178
That's a bad plan.
The pressure from the plenum is required to keep the bov closed while on boost
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502191
Seriously. Just run the stock one, or buy an aftermarket plumback one and plumb it up. If you really want to change the noise (this is the only reason I changed mine, because I don't like the stock BOV noise, not I wanted a hektik sound) then you can still change it with a plumback, and get none of the drawbacks of an atmo.
It's not worth the trouble of defects and getting harrased all the time.
  • Like 1
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502245
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
