just a question on dead coils...
I have all the symptoms of a dead coil
misfire on idle, misfire at low rpm, low power, high fuel consumption
but the car also stalls, do dead coil/coils usually cause the car to stall?
Also the problem seems to be gradually getting worse and worse
when it started, it was only a random misfire now and again, now even starting the car is a hassle
dont just go and change your coils if you get a missfire. i had the same thing and went looking for prices for new splitfires. Then i found a thread about cracking housings and arcing problems. I pulled my coilpacks found one TINY crack, slapped some insulating tape on it and its been perfect ever since. If you have a crack thats causing it to arc out and not a problem with the coil itself, resistance testing wont help you.
Yeah, I had my coils out on Saturday & the front 3 had hairline cracks on the front face. The back 3 coils were fine though.
Checked the resistance cold & I think my multimetre must be a little out of whack as they all measured 0.5ohms. But they were cold hence the resistance was a little lower.
New NGK BCPR6ES gapped to 0.75 but still a bit of hesitation at max load at 4500 - 5000rpm. Old plugs indicated decent mixtures but this may not be so all through the rev range.
  • 5 weeks later...
