So why are you changing pistons if Adam didn't?
Becaue theres many examples of stock pistons cracking ringlands. Ive gone aftermarket because they where cheap and for knock resistance (although ive gone e85).
Fair play people want a cheap insurance... but insurance from what? Im still yet to come across a stock rod failure thats not caused by rod bolts. Let alone anyone whos come to this topic with a massive failure. Which is the point of this topic and no one has come close to answering yet except for one person.
This r34 gtr will destroy so many myths about what people think how a rb26 should be built.
Edited by Cateans05
Mercury ran 850hp at all 4 (630Kw) in their R34 GTR on 43 PSI with a stock bottom end from what i remember.
They too wanted to find the limit and were expecting failure.
Finding the limit is sort of like playing Russian roulet, one engine lets go at 450Kw, another at 650Kw, so whats the real known limit?
There is no magical number.
There is only toss a coin and take a gamble.
But remember one thing, rod bolts are a stressed item, when new they can take more stretch and pounding, once cycled too many times they become fatigued.
Guess what happens next? ......
  • Like 3
So people are going to think an rb26 should be built with second hand pistons? :)
As said, some engines make heaps of power. Some don't.
Often the unopened engines are the ones that don't break. Heaps of well built engines fail due to silly mistakes.
Good luck with it.
  • Like 1
Lol These pistons have been measured and tested. Theyre in perfect useable condition.
Thanks, be sure to check back in 6-12 months!
I just spoke to Adam via facebook. His car held up fine and took a pounding! Mad :)
Edited by Cateans05
if an engine fails...and doesn't just wear out.
then the components can't handle the application.
Adams car lasted 1 event. It may throw the legs out of bed next time he drives to the shops.
are you prepared for a massive engine failure op?
Well there are guys making 4ooplus and Royce made 510rwkw on an unopened neo, With cams and springs, and head studs replaced leaving the head on.
Do that.
And get the awesome neo vct action.
  • Like 1
Just dont stress the engine, the moment a rod bolt goes through a few high stress cycles it will weaken and fail eventually.
This can be seen in motorsport, prostockers throw out rods after so many runs, track engines getting new fresh rods every season or 2, F1 engines detunned to survive just a few races.
Its all based on metal fatiuge which is why most people stay away from second hand pistons and rods.
Id only use second hand parts or stock parts in a stock build, where the parts are working within their designed conditions and parameters.
  • Like 1
Do that.
neo rods are rb26 rods ;)
Wait, that was with stick springs. New springs and more boost was 568kw. Below your rev limit.
Do that
Hahaha nah thats WAY to much. Im keeping it within the avearge stock 26 gearbox parameters.
If you're going to build a slapper that's probably the way to do it. Just use new rings and make sure the bores are the right size. Rods are probably already balanced with the pistons if they're still assembled. Get them rebalanced if you're picky
Thats more or less the gist of it all. Luckily im doing 70% of the work, that will save me thousands. So i can afford to pull it down again later if need be. Ill be sure too post back here wth results etc
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
