Selling all of my RB25 parts, including the engine itself, all the parts listed as a package made an easy 300RWKW on pump fuel, all parts are in excellent condition, i'm only selling to complete an engine swap, ps before you ask NO STINKING LS HERE.
RB25 motor no looms or bolt on accessories: $2000
Bottom end is nothing special just a stocker, doesn't breath or anything though, head was rebuilt approx 2 years ago with new valve stem seals, guides and seats relapped. Currently has a set of Tomei Poncams installed, i cant remember the specs, but they were the drop in ones that didnt need springs or anything. Also has a Spool high volume sump and genuine Nissan harmonic balancer which is also approx three years old
Garrett GT3582R, Tial 44mm wastegate, 6boost manifold package: $2200
Turbo has a T3 flange, external gate 0.82 housing, it had a new core around 2 years ago but has only done around 5000k’s, comes with a 90 welded onto the outlet of the compressor housing and all fittings and braided lines to suit an RB25, each line has fire/heat shield tube, I’ll also send the heat sheidling for the manifold that I made up too, The dump pipe is included but not sure how I’ll go freighting that due to its size.
ID1000 injectors and alloy fuel rail, $500
Tial blow off valve with new steel weld on flange and vband clamp $200
OS Giken twin plate clutch, sprung center, it was rebuilt buy NPC approx. 3 years ago, heaps of meat left on it, drives like a standard clutch with pretty much no rattle $1000
RB25 Power FC with hand controller comes with some pretty awesome looking purple paint on it, thanks to my mate who got carried away with the paint gun, works great though $800
Nismo (I think???) R33 Copper radiator 52mm thick, looks average but works awesome I’ve never had any heat issues or leaks even on 35 degree days at the track $200
Just jap intercooler and piping, 600x300x76 3 inch inlets excellent condition, Plazmaman alloy pipes to the inlet manifold $300
Custom aluminium oil catch can to suit R33, somewhere around 2-3 litres maybe bigger has two inlets and an outlet to plump back into sump $500
RB25 Clutch fan $100
Gizzmo Boost controller $100
HKS Turbo timer $50
Items are located in Gippsland, Victoria and am willing to freight at the buyers expense.
For anyone interested please PM or email me <script cf-hash='f9e31' type="text/javascript"> /* */</script>,
Heres a few pics of the PFC, you can see the paint on the ecu itself, there is also a film of overspray on the hand controller. Also forgot about the repair to the controller lead, it got melted at one point a number of years ago, works fine though.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
