Selling all of my RB25 parts, including the engine itself, all the parts listed as a package made an easy 300RWKW on pump fuel, all parts are in excellent condition, i'm only selling to complete an engine swap, ps before you ask NO STINKING LS HERE.
RB25 motor no looms or bolt on accessories: $2000
Bottom end is nothing special just a stocker, doesn't breath or anything though, head was rebuilt approx 2 years ago with new valve stem seals, guides and seats relapped. Currently has a set of Tomei Poncams installed, i cant remember the specs, but they were the drop in ones that didnt need springs or anything. Also has a Spool high volume sump and genuine Nissan harmonic balancer which is also approx three years old
Garrett GT3582R, Tial 44mm wastegate, 6boost manifold package: $2200
Turbo has a T3 flange, external gate 0.82 housing, it had a new core around 2 years ago but has only done around 5000k’s, comes with a 90 welded onto the outlet of the compressor housing and all fittings and braided lines to suit an RB25, each line has fire/heat shield tube, I’ll also send the heat sheidling for the manifold that I made up too, The dump pipe is included but not sure how I’ll go freighting that due to its size.
ID1000 injectors and alloy fuel rail, $500
Tial blow off valve with new steel weld on flange and vband clamp $200
OS Giken twin plate clutch, sprung center, it was rebuilt buy NPC approx. 3 years ago, heaps of meat left on it, drives like a standard clutch with pretty much no rattle $1000
RB25 Power FC with hand controller comes with some pretty awesome looking purple paint on it, thanks to my mate who got carried away with the paint gun, works great though $800
Nismo (I think???) R33 Copper radiator 52mm thick, looks average but works awesome I’ve never had any heat issues or leaks even on 35 degree days at the track $200
Just jap intercooler and piping, 600x300x76 3 inch inlets excellent condition, Plazmaman alloy pipes to the inlet manifold $300
Custom aluminium oil catch can to suit R33, somewhere around 2-3 litres maybe bigger has two inlets and an outlet to plump back into sump $500
RB25 Clutch fan $100
Gizzmo Boost controller $100
HKS Turbo timer $50
Items are located in Gippsland, Victoria and am willing to freight at the buyers expense.
For anyone interested please PM or email me <script cf-hash='f9e31' type="text/javascript"> /* */</script>,
Heres a few pics of the PFC, you can see the paint on the ecu itself, there is also a film of overspray on the hand controller. Also forgot about the repair to the controller lead, it got melted at one point a number of years ago, works fine though.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
