Yes, of course it is. Go and try to get something fixed and see how you go.
They will always say it was a pre-existing condition (how are you going to prove otherwise), or you caused the defect due to abuse (again how are you going to prove otherwise). There are fewer more unscrupulous people in the world than used car dealers. Ask anyone that has ever tried to claim anything on a 2nd hand car warranty. The devil is in the fine print.
yeah. unless the engine falls out as you are driving the car away from the dealer when you bought it.. you are most likely out of luck. Most 'used car warranties', aren't worth the paper they are written on.
I did get a new muffler under used car warranty once, but only because it was the service manager's last day before starting a job with another company, so he didn't care!
According to most used car dealers, pretty much everything is wear and tear/consumables and therefore outside the scope of a warranty.
In NZ we're covered by the Consumer Guarantees Act that states a good must be in serviceable condition for a length of time that would be reasonably expected of that good, so if it fails within that time it's up to the retailer to repair/replace/refund the item. Because of this extended warranties are largely pointless.
Of course, "reasonable" is a term that's subjective, and that's where issues come in. You might expect your newly acquired car to go for 24 months without a significant fault but the dealer might think 3 months is long enough. There's bound to be a simliar law in Australia.
lol "may be useless" - I love your glass half full attitude.
You have been had by one of the best car dealer scams that has ever been conceived.
Don't worry about it. If worst comes to worst you take your car to try and claim on any 'warranty'. If/when they reject is you get heavy with them and point out how interested the ACCC/Current Affair and the like are interested in stories like this. If they cave you get your car fixed - if they don't you pony up the cash and fix it yourself. That is life.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
