Just buy NGK copper plugs from your local auto store/s. Depending on boost levels you may want to run 6 or 7 for your heat range. Usually the plugs come 1.1mm gap, simply gap them down to 0.8mm and put them in.
May as well check your coil packs and ignition leads at the same time to prevent issues during tuning or down the track.
I can tell you right now that you should definitely be pulling more power closer to 300kw if you are using factory injectors/pump (at their limits). Running the 9's at low boost you'll get increased lag, assuming you are chasing response you might want to consider your fuel system options to prevent that. Obviously factory clutch might become an issue possibly unless you put a better one in with the motor out and other issues arise.
Final question, what made you rebuild your rb26 with standard components and not aim for stronger internals or head work?
Cheers for the reply. I was in a bit of a rush with the initial post as the donk is not completely standard. to be honest 300 is the aim I was just being conservative.
it has Forged pistons, upgraded rods, oil restrictor, sump baffle, tomei metal gaskets. its not over the top but should do 300awkw pretty easliy. My goal with the -9's is to run about 20/21 psi as the haltech will do that by default
The clutch has also been sorted. its new and not stock.
Sounds good and perfect for 300kw, nice figure and I am aiming for around 330kw at 20/21psi with my setup once complete. I am also using hks gt-ss's which are -9 equivalent.
But yeah make sure the fuel system and ignition is sorted correctly and you should get good results with the setup you have.
Stock camshafts will still be good but if you put in adjustable cam gears you might of done some camshafts at the same time to give you that increase.
With regards to plugs, there are two types you might need to try to find what works best for you. Consult your engine builder/tuner to see what he might suggest but it is a matter of trial and error really. But if you have new ignition components then you probably won't see any issues.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
