My Name is DJ
Hello from California USA. I just got mine well not technically because its still on a boat. Hopefully in a few short weeks I will be able to see it for the first time.
I also have a 2016 STI and a 2004 SRT4 Stage 3
Edited by 2BADBEAST
Seriously though! If a 1200HP Bugatti Grand vitesse w16 quad turbo can get a California plate and pass smog I know that the RB26 can easily. Sounds to me like It's more political than pollution related obviously. From what I've researched It's been done but the costs to bring a gmv into compliance are upward of 10k, and well 15k is what I was quoted for the skyline then it has bi annual smog to pass regularly so no aftermarket mods either. Thats absurd I just want to go to car shows, visit the track and occasionally cruise it around with other classics. It wont even see 1500 miles a year. We have stupid hippies running things around here though. As soon as it arrives godzilla and I are going on a vacation to a no smog state for a few weeks to visit some family.
Edited by 2BADBEAST
12k Is not a bad price. Any pics? GTR?
Damn I only paid $12k for my car lol couldn't imagine having to pay another 10-15k just to drive it on the roads.
Haha u really do need to get out of there. I'm still surprised New York isn't so stricted aboot this stuff
I didn't have anything to do with the import process. Bought it from this dealer.
http://japaneseclassics.com
They are awesome there. They do all the importing and don't put the cars up for sale until they are at their shop in Richmond. Basically it's just like buying a car like normal lol no hassle of doing customs crap and trying to do anything international
Edited by B-Turbo
  • Like 1
My name is Evan, originally from the U.S. (Houston,TX) but living in Japan now
Prior to moving to Japan I had a Mazda 3 (Axela) hatch with a high compression built block
Put cash down today on a Nissan Stagea Autech 260rs, should be delivered by mid next week
I'm thinking I went through the same agent as @sopwey
Edited by ebellis
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
