Got some good parts that are a waste just sitting around. Trying to price them aggressively lower than what I see right off the bat.
Set of 4 Stock rims (1998 GTST). No physical damage just scuff marks. - $230
Cam angle Sensor. off a RB25DET - $50. Can confirm working condition. Used this to check a timing issue and both my own CAS and this one were not the issue.
Set of 4 Gates Belts. Brand new never used -$30
Brand new Intake manifold Gasket -$10
S1 Ignitor module, genuine, great condition, can confirm working -$50
Genuine Walbo 255 pump -$10 Came out of a working car but cannot confirm condition after a few yrs hence the price.
R33 Battery Fuse box -$20
Series 1 R33 Rear HICAS steering rack unit. -$30 A working spare I got from a wrecker but never fitted. Ball joints don't feel like they have any play in them. The various control arms are off a different R33 GTST. $10 for the lot of them
Complete front 5 Stud Hub Assembly of a R33 GTST- NON ABS- Bearings feel good. -$30
Lastly A Pair of front HUB assembly. They are somewhere in the back of the shed in bags so I don't want to get them out for nothing, but its the complete Hubs with the control arm still atached like this
2012280811101446_w_0500-Resized320x240.j
PM me or txt 0421 605 491 for more info.
Edited by sonicz
Some more parts
Rear seats, good condtion - 30
Ac Evaporator Core - 30
S1 Headrest - 15
Will be uploading S1 R33 GTST headlights later on when I can get a pic. $80 for both, one of them has a broken front plastic lense.
Edited by sonicz
Everything is for sale as pictured. So one of them has a tyre the other 3 don't. But its not worth keeping.
Even if they all came with tyres you should replace old tyres that have been sitting around anyway.
I think the size of the stock wheels are 225/50/16
Edited by sonicz
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
