Hey I know a lot of people will say stick with standard cams but I'm about to do the timing belt water pump and heater hose upgrade on my 32 gtr. I thought at the same time I will change my cam gears to adjustable and drop in some cams.. here is a little list of what my car has done to it;
Hks gtss turbos
Midori seibi dumps
Full exhaust
E85
1000cc injectors
Its getting 310 rwkw with standard internals
If anyone could recommend a good cam setup for this that would be great thanks
Yes they are pretty minimal.
I would spend the extra cash on something more important.
But i didn't... So that statement is void.
Type B FTW!
Type Bs are great as long as you're happy with a car that drive terribley down low for the benifit of it going wank wank wank at idle.
I thought so much of those cams I literally gave them away cause I couldn't justify taking anyone's money for them
  • Like 2
How can type bs make a gtr with gt-ss drive Terribley down low
They already responsive as f**k ! I been in my mates before and after type bs noticed no difference down low
I should find out what gains he got with cams....
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
