Hey guys
Looking at swapping my r33
I'd love a gtr I do have cash I can throw in
Exterior
Genuine gtr bumper
Carbon fibre grill gtr
New painted factory side skirts
Gtr style rear pods
Gtr fibreglass spoiler
Bnr34 side skirt extensions
Jjr weathersheilds
Work meisters
Front 18x9 +30 Pirelli p1 tyres
Rear 18x10 +20 long life semi slicks
Suspension
Bc gold coilovers
Jjr rear cambers arms
Jjr front castor arms
Hicas lock bar
Dba 4000 series t3 slotted rotors
Ultimate pads
Interior
R34 gtt seats
Sparco leather steering wheel
Hkb boss kit
Sparco gear knob
Shadow boost and oil pressure gauges
Drift electric water display
Pioneer double din
Vibe 6" speakers
Vibe 6" splits
5 channel amp oa
Twin 10" woofers in Removable enclosures
Motor
Rb25det
Gtx3076 .82 all speed flow lines
Powertune steam pipe high mount manifold, genuine gasket,studs and nuts replaced
Turbosmart 45 mm hyper gate with speed flow lines
Turbosmart boost solenoid
Hybrid front mount
Custom cooler piping
Forward facing plenum
Deatchwerks 740cc injectors
Turbosmart fpr800 fuel reg with speed flow
Walbro 400 intank
Timing kit done with genuine water pump and thermostat
Tome Poncams 256
Cooling pro radiator
D1 spec overflow tank
Arp headstuds
Apexi Headgasket
Custom mild 3" dump pipe
Factory location blitz front pipe 3"
Catch 100 cell cat
Hks 3 3/4" catback
Varax cannon muffler
Greddy catch can with speedflow
Carbon valley and timing cover
Exedy heavy duty clutch
Haltech platinum pro plug in
Haltech boost controller
Haltech wideband controller with gauge
Car made 310kw on bp98
Edited by stump_69
https://www.sau.com.au/forums/topic/456537-300kw-r33-coupe-nsw/
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
Hey guys, just moved house and waited ages to get internet back on.
Anyway, interested in swaps for a 34 gtt.
Or 20k cash
got receipts for over 30k, not a Chinese built car I only used good quality gear, in doing so it hasn't had a problem in over two years since being tuned by powertune
If I can't get what I want I'll buy a 34 shell and swap everything over
Or 20k cash
Hey mate are you in Sydney?
Hey guys,
found a new car.
chasing 15k for the 33 without the work wheels.
recently has rear bumper resprayed as well
will not disappoint with quality of parts
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
