But I bet your good at Maths :)
Sorry ;) are you Malaysian too Colin?
Morning Colin. What's news?
Big weekend planned?
Haha, nothing MS Excel can't do :P
Yea I am a Malaysian too!
Apa khabar = How are you?
Not that much on for the weekend, just laze haha, might go down to Elizabeth Quay tomorrow....I haven't been there even though I work 2 mins from it.
Hai Hank :wub:
Hai Hank :wub:
Pasar Malam = Night Market at Elizabeth Quay tonight [emoji6]
Oh Hello Colin [emoji6] Khabar Baik [emoji28] Malaysia Di mana ? Juga Perth Di mana ? [emoji108]
Sarawak, born in Sibu but grew up in Brunei then few years in Miri, now Perth....cockburn central area. Yourself?
Born In Kuala Lumpur , grew up in KL & Penang , Few years in UK , Sydney , Melbourne
And finally reside for good 13th Years in Perth ( Mindarie North) [emoji28]
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
