I know right?
I've noticed R33 parts are pretty common though. The wheel Arch thingy that I need, not so common. It seems to be the one part that EVERY ONE needs.
Give him a call and his name is Louis[emoji13] make sure you have 1lt or Choca mocha handy for done deal X
Not really any use for me. Wouldn't hurt to have, I guess. The stuff I really wanted is gone. a CAT wouldn't be a bad idea...but I can't fit it in my car I don't think. Don't worry about it Ellie. Thank you for looking out for me though!, I appreciate that!.
as for FabCar... I've heard some shady things, their reviews aren't too flashy either, never dealt with them personally though.
  • Like 1
No worries at all [emoji13] I'll keep looking out if there's any [emoji3]
Saw their name on the side of a racecar recently
What you getting done?
Yer i checked out that white clean GT-R but out in the yard i seen another r34 gtr but the front looked like it was in a crash n they fixing it just put me a step backwards
Oh there is a topic about that car, called pre inspection something something in wa section
Thanks
I actually had a read of that post about a week ago i just can't believe I did not connect the dots i feel very stupid now [emoji52]
Thanks
Its a long shot but try calling some of the tuners I use C-Red, mark is a top bloke see if he or any other tuners are aware if any customers are selling and having worked on the cars can vouch for em? Like I said its just an idea and if they are aware you want one might be able to keep an eye and ear out.
  • Like 1
Hi everyone
Anyone have any experience with fabcar ?
Their cars used to be overpriced, but they had some good stock and have been around for years.
I remember they had a fkn mint Aristo in there once but they wanted $19k for it (this could have been 5 years ago), it was tempting but still overpriced for the time.
They have a Nice White r34 GT-R for sale
Make sure you use these guys before purchasing a decent car like that
https://www.facebook.com/Japanese.Odometercheck/?fref=ts
  • Like 1
anyone know if Wheel Arch Liners are required to get a car over the pits? (every wrecker i've called, and every gumtree add I've responded to, don't have them).
try calling KYP at Welshpool. They may have some, cant be sure.
  • Like 1
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
