Oh, here is a photo of the freshly washed R33 4 Door, nearly ready to get some plates slapped onto her. (not embedding because the photo is huge)
Theres so much bird poo burn on her, as well as weird stains that I just couldn't remove and some weird blue-tacky glue stuff that's somehow leaked onto her. My current tools were not able to remove those.
Also plenty of scrapes and dings but hey.... the car was less than $3k and I'll sort those out in time.
http://i.imgur.com/2L4mPAo.jpg
Current plan: Mesh Grill, Remove rear Window Tint and Fit the Wheel Arch Guards. Then either drag my mate around to fix the Electrics, or if he really can't make it, drive the car to KYP, have them fix the electrics and prepare her for the pits.
Take Car over Pits, Get Licensed. If the car doesn't get licensed, fix whatever they want and take it back.
After that I need to save some cash, and then I move on to fixing the body and adding a few things (Reverse Camera, new Head Unit), and then we shall see about making the car perform better.
  • Like 1
Not bad... For a 4dr
Reverse camera? Moar powerz!!
The car has a front mount intercooler, GFB bleed valve, Splitfires, Pod Filter. It's currently running the stock Turbo and BOV. It's also had the Oil Filter re-routed for easier access.
Here is a photo of the engine bay, taken just before I fixed the leak: http://i.imgur.com/8AMJuJm.jpg
Did I mention it was rebuilt 50,000km's ago and was resprayed candy apple red? along side all new piping (which was tig welded, but needs a polish).
It's plenty fast enough for now.
Truthfully, I have no idea what to do with the engine...bigger turbo? aftermarket B.O.V?, ECU + Tune?.. no idea yet.
Things I definitely want: Coilovers and Sway Bars, New Breaks + Rotors, Braided Break Lines.
edit: fixed some bad spelling
Edited by Manne
  • Like 1
Def ask before spending on engine. Trap for new players is that many advertised parts on eBay etc are crap. Not crap built but design. Standard bov is fine
Many threads with newbies who bought a tone of cheap engine parts then join Sau to find out why their car comes onto boost at 6500rpm and only has 250hp, if it didn't blow up first
Good plan right there. 25's respond to minimal mods half the time, quality high mount/manifold/gate/exhaust/injectors/ECU. Got one down here putting out 600hp with standards internals bar head gasket and cams
  • Like 1
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
