Not yet but will try go over next few weeks!!
They have few shops in Perth , one is at mill point and the other shop is in Vic Park ( former Mahsuri Restaurant:) The shop owner is one my friends :) Zac & Shari :)
I don't think I've lost that much - but yes until today I still have people commenting on how much I've lost. Hubby reckon I'm being a girl paranoid about my weights , truth he don't understand , I've been there [emoji28]
Floating between 67-72? Depends what I do at the gym. Basically when I started Uni 52kg. Moved to Perth + stopped smoking went from 52kg up to 58kg. Then slowly rose to 65kg from no exercise. When I started gymming....65 to 70kg in 4 months. A lot of rehab work cause my back and knee injury. Built back a lot of muscle. In high school I did a lot of track n field. Lol now can't even run 800m and not feel like dying.
  • Like 2
Btw, admire you and have so much respect for you hahaha wish I had that kind of discipline. Really need to fix my back. My knees are not really fixable lol
say yours is 72kg that's not bad for a guy , 80kg is prob a good / ideal weight for a guy ( not fats weight ,
Muscle weights I meant ) it's not too late for you to change it back into your healthy range, just discipline.
I enjoyed my daily morning cardio before my brain goes crazy at work , i find cardio helped with my stress level hahahahaha .
Oh mind I asked what happened to your back and knee injury ? Car or motorbike accident ? Have you got it check ?
Again thank for you for your compliments , I have long way to go [emoji22]7kg to go [emoji28] I've gotta start my strict diet soon , tuna and green salads [emoji30]
Haha I'm 169cm. 72kg is enough lol anymore I'll be worried cause the moment I stop gymming I'll put a lot more on lol.
Back was just injury from work. Inflamed and disc slip. Fell down.
Knee I'm not too sure how I got it. Knees hurt when I exert too much pressure. Was prob wear n tear from high school but when I started gymming I did a lot of legs. Leg press I got to 220kg in 3 months and then started hurting heaps so had to stop. Went for MRI on right knee after a year and half or so (only cause I was going for Everest Base Camp trek). There was a hair line fracture on the muscle.
The trek went surprisingly well. No issues on back or knees. Now all I can do for knees are a lot of stretching and rolling out muscles esp during cold weather. Might go for another MRI and see if it's gone and maybe find out why it's still hurting? A small tear like that should heal relatively quick but the pain has been there for a very long time. Shrugs.
Disc Slip is a worry! You can't carry any heavy weights lifting , that's Goanna hurt or Injured your back badly [emoji22] how old are you ? Sorry to ask
Have you try traditional way - Urut ? Heat massage ?
Also I find deep heat or soaked your body a in cold water, icy cold help the blood circulation, especially if your muscle sore after workout
Edited by ElleAli76
Haha I'm 29. Back is very good now. Havent had issues for the last year. Definitely going in right direction. My PT is good as he specialises in sports injury and the likes. We did a lot of core work for a long time. Now can feel all that suffering is paying off!!
Used to go for massages etc. now don't need it much at all :) deep heat definitely helps especially in this weather
  • Like 1
PT good ! They know better as they study and learn before they can become a personal
Trainer hahahahaha [emoji28]obviously! Core work is good and it help getting your sexy abs [emoji23]Hahahahahaha
Anyway lights off for me now mate, hope you get your body check and fix it lol - speak soon and have a good night all ! [emoji123][emoji111]️[emoji99][emoji99][emoji99][emoji99]
Edited by ElleAli76
  • Like 1
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
