10 hours ago, Manne said:
Nice. And the tune?
My car gets the shakes at 100kmph, steering wheel vibrates likecrazy
Sounds like your front tyres are out of balance.
(protip - if you can feel it through the floor its suspension, alignment etc, if the steering wheel vibrates, its the tyres. You have probably flung off a balancing weight)
  • Like 1
Nothing much. Busy at work and my lip got sent to America instead of Australia even though my address says Western Australia. Go figure. A few more weeks of waiting to get my bumper n lip fixed. I guess I have extra air intake atm [emoji23]
[emoji24][emoji24][emoji24][emoji24] that's so wrong !
Um so there's a import meet in Westfield whitfords this Saturday night.  z00key Myself and shoey are probably going to head out together as were all South river. We can meet up there or somewhere else just before. What do you want to do?
  • Like 2
15 minutes ago, t_revz said:
Gap plugs down further?
What gap are they now? I'm down to 0.65mm and no miss at 25psi with splitfires
Think my turbo would give up as I'm led to believe it has the nylon compressor wheel.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
