Was good meeting you trev hope the tv does all the things u needed it to do, you got a good one there (even tho it wasn't a samsung [emoji6]
Yeah I can't wait to pick it up naow. Gotta love new toys :)
We sure are. i'm getting real low.
Hey Brad, havent seen you in a very long time since Ford from memory. Seen Dale the other day, he popped in for a quick chat when he was dropping some equipment off at new spud shed.
Spent the weekend at Bunker Bay with the wifey for our 1 year anniversary. It's so nice down there
  • Like 2
Gday Corey. Yeah my Ford days were probably the last time i was around. They were going bust so I jumped ship and now driving trucks around the country.
Thoughts id comein nd catch up with everyone. ... but they all gone :(
Yeah everyone disappeared a while back, Lyell is in Greece at the moment working, Dan is going nuts with his photography and other ventures, Dale is driving all over the place aswell.
Dales driving to?can you pass my number on to him puhleeeeese :) 0402 507 738
33 minutes ago, z00key said:
But there are a few new guys who can be good to know if you require electronic goods ;)
Woukd have been goodto know a month ago hahaha but definitely keep this in mind :)
  • Like 2
But there are a few new guys who can be good to know if you require electronic goods [emoji6]
And Girl ! Not like I do the electronics but yea def there's a girl on this forum too [emoji28] x
  • Like 2
13 minutes ago, ElleAli76 said:
And Girl ! Not like I do the electronics but yea def there's a girl on this forum too emoji28.png x
They let girls in here now????MINDBLOW!!!!
Nice to meet you Ellie. ?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
