Was good meeting you trev hope the tv does all the things u needed it to do, you got a good one there (even tho it wasn't a samsung [emoji6]
Yeah I can't wait to pick it up naow. Gotta love new toys :)
We sure are. i'm getting real low.
Hey Brad, havent seen you in a very long time since Ford from memory. Seen Dale the other day, he popped in for a quick chat when he was dropping some equipment off at new spud shed.
Spent the weekend at Bunker Bay with the wifey for our 1 year anniversary. It's so nice down there
  • Like 2
Gday Corey. Yeah my Ford days were probably the last time i was around. They were going bust so I jumped ship and now driving trucks around the country.
Thoughts id comein nd catch up with everyone. ... but they all gone :(
Yeah everyone disappeared a while back, Lyell is in Greece at the moment working, Dan is going nuts with his photography and other ventures, Dale is driving all over the place aswell.
Dales driving to?can you pass my number on to him puhleeeeese :) 0402 507 738
33 minutes ago, z00key said:
But there are a few new guys who can be good to know if you require electronic goods ;)
Woukd have been goodto know a month ago hahaha but definitely keep this in mind :)
  • Like 2
But there are a few new guys who can be good to know if you require electronic goods [emoji6]
And Girl ! Not like I do the electronics but yea def there's a girl on this forum too [emoji28] x
  • Like 2
13 minutes ago, ElleAli76 said:
And Girl ! Not like I do the electronics but yea def there's a girl on this forum too emoji28.png x
They let girls in here now????MINDBLOW!!!!
Nice to meet you Ellie. ?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
