3 minutes ago, ElleAli76 said:
Thanks Corey, I might do the Same since the online parts from Japan took forever emoji22.png
Cleary buying from the wrong places.
My Cusco strut brace was sent on a Thursday and arrived 5 days later on a Tuesday.
  • Like 1
