2 minutes ago, pol1on1 said:
Who knows how to use yahoo auction Japanese ?
Is it possible to get stuff sent hear to aust ?
I have purchased something off there before and by the end of the transaction it is not that cheap with all the extra fees etc (came to about double what auction item was for), I had a mate who used to live in japan do it all for me as on some of the payment screens google/chrome didn't translate very well. It is possible but I would only use it if its something that you just can't get anywhere else? People on here may know of different ways around this but I can only speak from my experience.
  • Like 1
Ok thanks
Probably this will be the case as the stuff i like always out of arms reach thats just my luck. [emoji30]
I want the genuine centre trim C/F 1485477659580.thumb.jpg.8e2500e636ba05b3
I think this is the nismo opinion.
It would look better than my carbon wrap. [emoji12]
  • Like 2
Ok thanks
I want the genuine centre trim C/F 1485477659580.jpg
You can try the company's like import monster that can do and arrage everything for you? Or just book a flight its an awesome place one weekend go to airport bags packed and buy a standby ticket for 2 days lol
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
