Fair enough, I thought as much too.
Can't wait to see and hear how it turns out.
All I can say is WOW!! It turned out to be amazing! Better than I had hoped [emoji106]?[emoji106]?[emoji106]?[emoji16][emoji16][emoji16][emoji344][emoji344][emoji444][emoji445]
  • Like 2
35 minutes ago, z00key said:
Never heard of it? Or nother name 4 crabs?
Pretty sure its Sunburn.
Just now, shoey85 said:
All I can say is WOW!! It turned out to be amazing! Better than I had hoped emoji106.png?emoji106.png?emoji106.png?emoji16.pngemoji16.pngemoji16.pngemoji344.pngemoji344.pngemoji444.pngemoji445.png
This makes me happy.
  • Like 2
I'd happily swap for crabs
When it hits I feel like clawing the skin off my back with a blunt nail. I'm sure sleeping on a fire ant nest would be more relaxing
  • Like 1
What did you get?
What did you get?
New sound system for the R34, JL sub and front splits, R type coaxial for the back, new deck alpine and got some amps from a mate who helped install it all. Sounds mint, quite loud too with a decent rumble [emoji16]
  • Like 1
Rain isn't that bad if you wash ya car outside use the rain as a final rinse after the hose it then garage it n dry it there [emoji2]
You gota remember scheme water has that much calcium and hard minerals in it thats why you get all them white dry dots. [emoji34]
Its like going to the car wash and getting the spot free rinse basically water runs though a water softener. [emoji16]
  • Like 1
