Morning all.@Hank Scorpio saw this unsure if any use but for your attention
Please view this ad:
Datsun 1200 Struts plus Wilwood brakes,
http://www.gumtree.com.au/s-ad/kingsley/brakes-suspension/datsun-1200-struts-plus-wilwood-brakes/1101371291?utm_source=com.google.android.apps.docs&utm_medium=social&utm_campaign=socialbuttonsVIP&utm_content=app_android
Price: $3,300
Download the application from the Google Play Store.
http://goo.gl/7NzhP
Price: $3,300
http://goo.gl/7NzhP
Fark, the things I could do with $3,300!
1) Buy a gearbox for RX-8
2) Buy a complete S13 for a front end conversion on the Datsun
3) Buy 3,300 chocolate bars on special at Coles
Cool and all, but wayyyyy overcapitalising on the ute.
  • Like 3
Yeah nah f**k 3300 plus you could probably buy much better through your work
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
