2 hours ago, ElleAli76 said:
Anyone wants to make some quick cash money ? $500'? No hard work needed
Texted you ♥
also: Power stearing hose all fixed, running smooth. Booked the Wheel rebalance for Wednesday the 15th. Happy Days.
  • Like 2
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
