Liquid limestone. Just finished prepping 2nd area. Quick bite to eat and I'll fire the mixer up default_wink.png
I have 3 kids and didn't get sleep in at all [emoji23]
12 hours ago, t_revz said:
What's the difference between x and black? Car price? How many levels are there?
There's UberX (normal), Uber-maxi whatever for large group and UberBlack which is swanky af.
Everytime you go up a level you pay more.
From what i know uberx is $1 per km while black (top class) is $2per km now there is one more in between its people carriers.
Also i did get charged a uberblack flagfall of $2 and 18min in car was $5.60.
  • Like 1
How much should I charge if I use my GTR [emoji38]
Went to work straight into nightshift did not sleep at home or plane was up for 22hrs. Went to sleep i can't sleep now after i woke up from 3.5hrs of sleep [emoji27] [emoji22]
Huh ? Too much sleeps ?
Im using my PC, don't notice a new layout.
Did some things to my car today, found out some new troubles with my car today as well.
Got some Quotes.
Back to saving $$$$.
Time to move it on b4 you overcapitalise
  • Like 1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
