Haha, I'll see what I can do but will definitely get you guys a table for soft launch. Hope everything goes through fine, just having some issues atm with leasing etc...hence been abit crazy busy
  • Like 1
28 minutes ago, t_revz said:
i probably wouldnt get a 200 series unless they were 50k
Yeah, probably worth that.
Brand new, top of the line would be worth more, but that depreciation though.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
