Going to watch, id like to get into improved production or the street cars but there not racing that nite. Its a mixture of cars, historic is normaly the most diverse. Old english, old american, old jap and old aussie cars
  • Like 1
2 hours ago, z00key said:
Na unsure been sore for bit over a year then about 2-3 months ago took off my shirt to hop into bed and just felt something tear, went had it looked at and well im sure everyone is familiar with the hoops u have to go thru in our medical system try this that and the other thing finally go to specialist only to fing have torn I think its called rotor cuff muscle so had a nice 3mm needle jabbed in it which so far has done nothing but gotta wait like 8 weeks if no good then surgery. Yey fun times
i tore my rotator cuff when i was 20. had all the tests including iodine injection while in MRI so they could 3d image the damage to the joint...not sure whether it was price or what but i never had surgery. i learned to live around it and there is only 1 or 2 things that really upset it but i usually dont even notice it anymore. its about 98% optimal now
but my party trick is that i can dislocate the joint just by relaxing and letting it hang down at the right angle.
  • Like 2
Yippee colin barnett is out !!!!
[emoji4] [emoji12]
Sooo dam happy of the result
Cheers colin for f**king our state that's now in debt of $27BILLON and predict to rise for 2016-2017 EOFY
Now with the mining boom over we got a great future to recover in
yer right !
[emoji15]
  • Like 3
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
