5 hours ago, colin.ssc said:
manne & z00key - with warranty claims with JB, do we need the receipt as proof of purchase or will it be in the system records?
you need your receipt or a bank statement so  we can get your receipt. If you don't have your receipt, you'll need to go to the store of purchase as other stores wont have access to it.
