15 minutes ago, Manne said:
you need your receipt or a bank statement so  we can get your receipt. If you don't have your receipt, you'll need to go to the store of purchase as other stores wont have access to it.
So if I don't have receipt I can still just bring the item back and they can trace it...as long as it was from the store I bought from yea?
Thanks man
so now if Colin doesnt come to see you, youll know hes been cheating on you and going to another store :15_yum:
@z00key i think i was telling you @racewars about one of the apprentices at work having an old crappy looking EL that went hard and had all the driveline break and then replaced to handle the engine after he turboed it.
today i found out he was actually there. his was a goldy/champagne coloured one. 262km/h over 1000m. 33rd fastest
  • Like 1
Thanks man
No, you need the receipt or a bank statement.
Lol, asking for the gf, her house modem died, they cant find receipt. oh wells sucks to be them.
good work, I recall you saying this.
Yeah I remember you saying that wondered if that was the guy who was taking the mickey out of him saying its one of the fastest taxis in WA lol. I also am having a few issues with the app (but android)
the funniest thing about his upgrades is that the transmission is controlled by 2 toggle switches in the centre console.
both on to stall up, turn off one to get 1st. then both off for 2nd, one back on for 3rd etc etc. so simple yet dodgy :)
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
