Yeah did a oil change Saturday. Had done 7000 so will change at 5000 now religiously it disappeared at idle after the change and is only 2800-3200 on no6 under gentle acceleration in second? Rattle rattle - gone? No noise with 6 coil pack disconnected! Weird.
how loud is it?
not sure if you can use an oil flush to get the gunk out... they arent too bad to clean apart from having to get them out. there are also a couple different varieties on our engines. look the same externally but different sizing internally
Haven't pulled the cam cover but goes away with no 6 H.t. Disconnected? So I would assume a cam lifter follower issue? Seeing as its on the exhaust side?
Series 2 R33 engine.
may sound like a dumb idea when your so confident of where the noise is buuuuuuuuutttt.......
its not an exhaust leak at the back?
  • Like 2
1 hour ago, Beyond Blue R33 said:
Can only pick up the rattle in 2nd gear under mild acceleration?
U should have a lisren to my engine, rattles at idle (suspect the turbo may well be dying lol) about 3k its got a ting ting noise and at the top it sounds like a big ol straight six on heat ?
Wouldnt be lifter, weather u disconect the coil or not it the lifters gonna do its job. However, if u disconnect the coil and it goes away ur taking the combustion away from that cyclinder. So id be looking for a leaky manifold around nunber 6 or anything in general todo with number 6
  • Like 1
U should have a lisren to my engine, rattles at idle (suspect the turbo may well be dying lol) about 3k its got a ting ting noise and at the top it sounds like a big ol straight six on heat [emoji23]
Yeah i panicked at first thinking ouch turbo, bearings, piston slap, gudgeon pin, big end knock etc. but can fully pinpoint the sound to no6 rear exhaust cam cover at only that tiny rev range. Will sus it out better on the w/end? Might need a real mechanic! Would assume tig welding it won't help!
Will suss it out better Saturday. Thanks for the advice guys, I appreciate it. It will give me a better starting point for trouble shooting. Never owned or worked on a car with a turbo or the cam shaft/s in the right spot except the last 8 months. Show us your v8's. She's running absolutely trick except for that! My wife and jack recond the noise is in my head! What noise! (perhaps the loony bin would be a better fix?) done all the turbo/dump pipe studs gaskets etc. So will check the manifold.
when you drive something often enough you can hear noises before anyone else or before it becomes a problem
Spent 3 months of weekends when I got it fixing rattles blips blurts knocks and bumps! Only drive her on w/ends. The captain always goes down with his ship. Then emerges with less money and More power!
  • Like 1
I remember having issues with the escort (when I was 18) flushed and cleaned everything new radiator, heater core, plugs points gaskets leads jets etc. I was putting a new head gasket on when dad came out and wiggled the no.4 piston with his hand. Think I found your problem mate! Sell it now.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
