1 hour ago, colin.ssc said:
Hey Folks, some of you may know I've been working on a new project with a few friends. It's finally up and running......(unfortunately it's not a car....). It's a restaurant, and it'd be really nice if you guys could come down for a visit! You can make a booking via our website at www.amanorestaurant.com.au
Elsie is looking to come down sometime next week (or when she feels better).
Also, if you could like the facebook page www.facebook.com/amano.perth and follow the instagram page www.instagram.com/amano.perth
Thanks so much for the support guys!
The wife and I will definitely check it out. Looks really good.
Edited by Manne
  • Like 2
its about time you stopped ignoring us for your "thing on the side" haha
  • Like 3
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
