Boys if you come across some stranger asking about me and my car , please do not pass any informations around -
This bloody terrorist been chasing me and few other R35's perth owners.
I'll go to the police tomorrow and lodge the complaint.
  • Like 1
I know nothing ?
  • Like 1
IMG_8596.thumb.jpg.99d7d99ad48a7d61bb67fd7612af4e77.jpgIMG_8599.thumb.jpg.a8a4222921f2f31997a39366e4c334c9.jpgIMG_8600.thumb.jpg.0c057fb5c4d7a570de03a8ebec29a721.jpgIMG_8601.thumb.jpg.08a6e3427673e51b40f417ea49101adf.jpg
Wtf not heard anything but will let u know if i do hear anything.
  • Like 1
This guy is so weird :( he's been chasing me everywhere , he even go to GS ( Galvasports) and asking around about my details , and now this ? My car detailer ? Like seriously ? we have been warned from other R35's owner not to deal with him , he got upset and start sent us all nasty messages :(
He sounds like bloody Arab or Afghan
  • Like 2
This guy is so weird [emoji20] he's been chasing me everywhere , he even go to GS ( Galvasports) and asking around about my details , and now this ? My car detailer ? Like seriously ? we have been warned from other R35's owner not to deal with him , he got upset and start sent us all nasty messages [emoji20]
Keep safe
  • Like 1
Just stay clear of them, sounds like bad news.
  • Like 1
2 different numbers with same Arab / Afghan.
We didn't ask for his Id or bank details. He sent us his Id picture and 2 years bank statement.
He talk shit over the phone saying previously he's got 3 of R35's - like if you already have 3 before why would
You want to buy mine ?
Sounds like he wants to steal yo' ride. Keep it locked up.
Also, Collin, Sorry I didn't get back to you, we were under the pump and under-staffed. Will sort it out asap.
  • Like 2
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
