All good till the government rips the ass out of what you have earned from busting your balls. Wow look at, oh, bummer.
Yep always paying the man
I've made 10-11k a fortnight plenty of times when they offer unlimited overtime but I think from memory I only end up with 6k
I feel you on the mega overtime. have done some 26-28 hour days. Get home, pass out on the couch for a few hours and then wake up for some dinner. Far from a good time.
That's the go, getting work to pay 26-28hours for a 24hr day
  • Like 1
Any updates?
It has been quoted, assessor to review then I will have an answer, it seems like it's repairable, we have discussed our tidy up [emoji14] the 34 will be very tidy after this I'm sure [emoji6]
We have a couple of ideas that if we go ahead with will really set the car apart from others [emoji108]
  • Like 2
Suicide doors and 24" mags?
  • Like 2
13 hours ago, shoey85 said:
It has been quoted, assessor to review then I will have an answer, it seems like it's repairable, we have discussed our tidy up emoji14.png the 34 will be very tidy after this I'm sure emoji6.png
We have a couple of ideas that if we go ahead with will really set the car apart from others emoji108.png
Ooooo sounds promising
Was thinking of strengthening the front a little and running a new cai
5F021C56-AA04-40BE-AE4F-270AAE88264A-1514-0000019928DF801A.jpg.b41678dceae543f796def36451ce8707.jpg
That will make it 2 of a kind then.
Fully equipped to bash roos and do water crossings. Traction and water ingress might be an issue you want to look into though.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
