I always found the rears wore faster (but near 400kw so. Traction? Lol)
Is this track mainly with occasional Street or street with occasional track?
R comps in winter/wet weather on the street would be sketchy at best, not great when cold or wet, terrible when cold and wet.
That aside, won't having less grip in the front just make the car more likely to understeer as the front loses grip before the back will unless you dial that back out with suspension setup.
400kw wpuldnt help wear lol....
Once built it will be mainly track, street drivingin the right conditions for meets and such. Suspension will be looked at nearer the time. Coilovers that are on the car are so hard its unreal lol
The teacher keeps giving examples of when she worked at X mine site with XYZ employees, and gives descriptions of each person in her story regardless if it relates to the story, and we get these 10-15 diversions and in the end she doesn't answer the question asked.
In 2 days we have spent less than 2 hours actually learning anything useful
  • Like 2
Oh no one of those. I became a teacher so I could gloat over my life's experiences again and again to a captive audience who be polite because they wish too pass.
If nothing else they will at least be more interesting.
DSC_0264.JPGDSC_0263.JPGDSC_0262.JPGFull size spare (16x205x55) with modified mounting bracket. 2 x 10" Rockford fosgate prime R2 dual 4 ohm wired to 2 ohm. 6 1/2" alpine type s 2 way rears.DSC_0253.JPG Type r splits front. 2 x 21.2ltr 19mm Mdf fully sealed enclosures packed with 2" inner bond wadding sitting on 6mm rubber suspension from body. Alpine 4ch amp for speakers. Cadence 2 ch for subs. 12mm ply wood false floor carpeted both sides with 6mm rubber insulation. Nearly finished just need to mount the jack and wheel brace.
  • Like 2
DSC_0264.JPG.bec96d82898d769f4d22bb61f4de0d02.JPGDSC_0263.JPG.2b66da2020c31dc6f47247a315597bfe.JPGDSC_0262.JPG.8dbe44fb43e8f0c5f5af21e3bde2a603.JPGFull size spare (16x205x55) with modified mounting bracket. 2 x 10" Rockford fosgate prime R2 dual 4 ohm wired to 2 ohm. 6 1/2" alpine type s 2 way rears.DSC_0253.JPG.e2cd11bab5dd7efba31b5c53846985a0.JPG Type r splits front. 2 x 21.2ltr 19mm Mdf fully sealed enclosures packed with 2" inner bond wadding sitting on 6mm rubber suspension from body. Alpine 4ch amp for speakers. Cadence 2 ch for subs. 12mm ply wood false floor carpeted both sides with 6mm rubber insulation. Nearly finished just need to mount the jack and wheel brace.
Looking gd bud
  • Like 1
Looking gd bud
Thanks man. Jack and I gave it some justice today. Blackened was awesome. Punchy tight and deep with good separation. Not a show winner by any means but I'm happy with the results. Angles, maths, wood, glue, nail gun, staple gun, sanding, sealer, wiring, carpeting, insulation, brackets, nuts and bolts, soldering, helm holtz theory of resination and ohms law. I'm pretty proud of the boy. He built the p/s box pretty much by himself with some help from me. Great father and son project:-)
Cant beat a bit of father son time. Especialy when it involves cars ?
  • Like 1
Can't wait to watch him whipper snip and mow the lawn next weekend! Fully grumbling under his breath:@
Bahahahahahaha, my wife loves the lawn mower.... its great lol
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
