14 minutes ago, Beyond Blue R33 said:
Don't get me wrong she's running and pulling hard at 18psi still. All temps and pressures are normal. Just seems to have lost a bit at say 6000 to 7000 under full load? Trevs? Kizza?
unless boost has increased then i'd think you'd be fine
34 minutes ago, ElleAli76 said:
Hows weekend for Everyone ? Next week Saturday - Any idea where we going to meet up before head Down to barbagello ? Cruisinnnnnn All
Together from joondalup ?
Whos going ?
remind me.... whats on?
  • Like 1
12 minutes ago, ElleAli76 said:
Might car mode event and Dave was talking to drive down to collie on Sunday for the track Race ? Apparently Lochy is going on Sunday
what event is on sunday at collie?
Lachy's wife is letting him off the leash for the day?
  • Like 2
47 minutes ago, Beyond Blue R33 said:
Panicked when we got to Toodyay. Jack was like there is smoke coming out from under the bonnet. Wtf. Bonnet was a bit hot with no blanket underneath it was steaming the rain over the turbo off the top of the bonnet. Was just running up the hills in 5th and loading it up on the way there with the boost controller off. Used 4th for the hills on the way home at 14psi no probs. Different animal to the 4,9 5.8 5.0 and 5.4 lesson learned. Bugger all torque at low revs. think I will get rid of the 200cell catco oval and go to the venom 100cell with the 5" substrate. Tuning is beyond my nuts and bolts ability. Any thoughts? We ran sweet to and from Albany and did 1000kms pushing it hard. The original 100 cell metal cat copped a massive smash over a trainline bump at full speed the substrate came loose and flew into the exhaust melted and killed it and we popped a intercooler hose because it blocked the exhaust.(the weekest link) have swaged pressure tested and redone all the tubes and hoses with a intercooler flush. Would I need to retune between replacing the cats? Any advise would be appreciated. Thanks.
What ecu have you got?
Morning boys ,
Here you go - start at 10am -4.30
We can meet up at 9am Joondalup shopping centre ( Muzzbuzz ) Car park.
Take the new freeway extension from Joondalup straight to Neerabup.
Or any other suggestions ?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
