The biggest issues with perth is its speed limits and people being stingey. People pay as little as possible for tyres, corse ur 20 dollar plastic tyres arnt gonna grip the road and not enspire confidence. How are you supost to drive if u cant feel what the cars doing??? Specialy in the wet.... and the speed limits, iv never understood why ud make giant v8s and have such slow limits. At 100kmh my concentration level is minimal as which i think most peoples is too. Lots of unconcentrated frustrated people makes for dangerous roads.
Where do I get these $20 tires? [emoji12]
Hey folks - unfortunately I need to sell off my Skyline!
Does anyone happen to know anybody who might be chasing a manual V36?  I have a good'un.  I thought here might be a good place to ask!  If you guys know anyone or have any tips, let me know.
As always - much appreciated!
James.
James.
That's no good mate, there are a few jap car Facebook groups
Saw the car tonite for the first time since tuesday, parts alone come to more than its insured for..
 So im at a bit if a crossroads, do i buy it bk and build a race car or rebuild it as a road/race car
Over night parts from Japan
And 2 of the big ones
f*kc didn't expect that!! [emoji24][emoji24]
10 hours ago, t_revz said:
Sup travis pastrana?
Making the most of the wet weather on the bike?
LOL no. Sad news is after 5 years of manual labour, I have fkd my spine again (3rd times the charm - looking at fusion this time) So the bike isnt seeing much use.
Actually looking into stripping the old girl down and rebuilding it as a retro street scrambler. Think old steel fuel tank, flat tracker eat and low riding guards front and back
*rummage*
  • Like 2
ALso, as fellow wagon aficionados, Y'all might want to take a squizz at this years pebble beach concours.
Apart from Aston Martin FINALLY releasing more details about the upcoming vanquish shooting brake. V12 2 door wagon out of the box with almost 600hp? Anyone in the market for a kidney or 2?
aston_martin_zagato_pebble_beach_1708201
Plus, Coco Chinetti Jr's hand built 330 Fez will be auctioned off. Previously owned by the junkie in the wierd hat from Jamiroquai its expected to get $1M +
gooding_monterey_pebble_beach_ferrari_sh
If you wanted it to be a race car you could buy it back and tube frame the front end.
  • Like 1
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
