Skyline update.... total loss however, i brought it back for 1000bucks [emoji3] plan is to strip it down and assess the damage underneath. If its ok, il rebuild it from the ground up [emoji48]
Great price!!
  • Like 2
$1000 bargain. We could start playing fish. Have you got a? Yep $1000. Have you got a yep $1000. What did the insurance pay out?
Would a new k frame fix the damage? Or is it more substantial underneath?
Main damage is radiator suport and bumper rio. Was gonna get a new front bumper and carbon bonnet anyways.
  • Like 1
When the 1.3bar rule cam in nissan moved into multiple cylinder tuning.  Each cylinder had its own fuel and ignition trim. So when they had it all figured out they actualy made nore horsepower than they did befor lol and for the endurance races they knocked the boost back to 1bar. They could safley get 4000 racing kms out of there rb26 @ 800hp in the early 90s.....most of the time they ran in rwd only but in the wet they actualy configured it to run 60/40 front bias to gelp pull the car out of the corner instead of pushing it out.
P.s, ur dad sounds like a legend!
Man those Gibson motor sport 32s are the stuff of legend. The one Richards/Skaife drove in 92 was up for sale recently. Came with 6 spare engines and boxes. Serious buyers only. (lotto win).
  • Like 1
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
