Pull the rail off and unplug the injectors without removing them from the rail and crank it, make sure it's not a bad o-ring.
Already done start of the year. Also had them cleaned. Tried winding Cas while spraying individually into a bottle and all spray pattern looked good. Replaced o-rings and refitted but still dilution.
Bought a wideband. Removed cold start enrichment and leaned out at cruise
Still dilution [emoji15]
Time to swap out injectors...
  • Like 1
What size injectors and fuel pump?
Blitzed spring onion, mushroom, white onion red onion and garlic. Caramelised and Reduced with red wine, browned lamb rump chunks, made custom gravy 2 1/2 hours in slow cooker. Fresh sesame seed crunch bakery rolls and creamy garlic mash on the side. Full dilution :-) deliciousness!
  • Like 1
Tasted like insane beef Wellington in a roll.
Aids?
  • Like 1
My missus made some tasty pulled pork rolls earlier in the week
Was dinner,breakfast, lunch and dinner [emoji4]
Yummo. 4 porks in 24hrs. My back couldn't handle it. Bummer about the unburned fuel past the rings. Would say maybe too rich or too aggressive timing. Too much duration on cams? Poor spray pattern etc. Worst case scenario hone or rebore. Compression test? Only a few thoughts. You know from a sheety. Have you tried pop rivets, tig welding or nuts and bolts. That's where my experience runs out so only a thought. it's just a thought. If my life is for rent.and I don't learn to buy. Do I deserve nothing more than I get. For nothing I have is truly mine. (Dido)
Aids?
Anything to do with beef pork or lamb and you're in:-) I've been recording the secret meat eats guy off sbs. Just smashed his beef Wellington recipe into the slow cooker with some modifications!
  • Like 1
New engine
Def not running rich
Cams are mild
One of the injectors is ticking so most likely that's the culprit but I don't wanna upgrade to top feeds unless I'm sure.
  • Like 1
I'm having issues with the sthil fs38 idle at the moment then bogs down under power so??? Tuning a Nissan??? Apparently I can't tune a 2 stroke whipper-snipper properly.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
