Sweet. The bro does 2 on 2 off, auto sparky/electrician/diesel fitter. 160.000 per annum. He can troubleshoot anything. I have more respect for that man than any other tradesman I know. Cats Cummins mtus Waukesha wartzilla diesel gas locomotives power generation. He has a bedroom at home with dedicated model train sets on all the locos hes worked on. Animal
Sounds like a clever Kent. 160k isn’t that much for someone with so many qualifications and doing FIFO
I’ve got a restricted high voltage ticket aswell but I’ve never had to actually use it so I don’t have any experience. Hopefully I automatically qualify for a lot of the criteria so I can skip through the training easily
  • Like 1
22 hours ago, Beyond Blue R33 said:
On 21/11/2017 at 8:08 PM, R33kizza said:
I know how you feel, moved houae at the weekend and been doing 4 hours ot a day. Working 6am till 9pm tomoz..... fml
15hrs pretending to be a German might not be germain to the situation. Just try to avoid their porn. Sebastian vettel calenders everywhere :-o
10.5 hours ot in 2 days.... tired doesnt even touch it! However the 135i sat on my drive is kinda nice lol
  • Like 1
I sell things. :)
  • Like 1
Dad's mate had a e46 m3 man that n/a 6 delivered power beautifully. You know, when it wasn't broken down. Dave's nephew just bought a xr6-t out of the yard at midway ford. Dyno at 400rw/kW. Still on p's. Hope he lives to tell the tales.
Faster than a speeding bullet, moar powerful than a locomotive, leaps to air-conditioning in a single bound. It's that fat ranga welding guy.
Dunno if I could handle being in an office full time... too many muppets
Temporary Australian
  • Like 2
Lucky it's summer. Imagine the boost spooling up with the button off in the wet. I've busted traction 3rd to 4th in the xr8 and the skyline in mildly damp conditions. At least the Nissan is direct and pointy when having to pedal it. The falcon has lovels Springs Koni shocks and adjustable sway bars but is still the worst understeering dinghy ever. That massive 5.4 quad cam engine is a f**king boat anchor compared to the Windsor's I've owned. High front centre of gravity. Still the wife's favourite thing. Makes moar noise. Thinks shes a legend shifting at 4500.
Not reli a bmw fan but thr 135 is a twin turbo 6pot, 300hp and there reli light.... gd fun. The motors gd for 500hp on factory injectors and internals. Turbos not to much but its engine out to change them lol....
Id contemplated a fg xr6t to replace the skyline but there so damn heavy... 1800kg.... fat sloth
Heavy yes, but a couple mods and it's putting down 350rwkw. A few more and it's pushing towards 400. all without touching the stock turbo.
that barra motor is a heavy mofo but makes power so effortlessly.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
